Old-Terraform
On This Page:
- Overview
- Volterra Quickstart Tool
- Installation
- Usage
- Subcommands
- Options for Subcommands
- Examples
- Volterra Terraform Provider
- Authenticating to Volterra
- Configure Volterra Provider
- Example Usage
- Argument Reference
- Configuring Volterra Resources
- Namespace
- Example Usage
- Argument reference
- Attribute Reference
- Origin Pool
- Example Usage
- HTTP Loadbalancer
- Example Usage
Overview
Volterra terraform is a docker container that contains the quickstart tool and the terraform provider. The quickstart tool is a combination of script and templates using which, you can perform activities such as site deployment and removal. The Volterra terraform provider is used to expose Volterra Services public objects as terraform resources. The provider is responsible for interacting with Volterra objects in the backend.
Note: The Volterra terraform provider is not yet publicly available. Therefore, it is made available through the Volterra terraform container
docker.io/volterraio/volt-terraform
. The terraform provider binary is available in the following path in the container:/root/.terraform.d/plugins/terraform-provider-volterra
Installation
Download the latest quickstart tool:
docker pull volterraio/volt-terraform
Extract the quickstart deployment script to your local folder:
docker run --rm -v \$(pwd):/opt/bin:rw docker.io/volterraio/volt-terraform:latest cp /deploy-terraform.sh /opt/bin
Usage
Syntax:
./deploy-terraform.sh <subcommand> [options]
Note: Use the script or the subcommand with the -h
or --help
option for more information. For example, use $ ./deploy-terraform.sh -h
to obtain information on available subcommands.
Subcommands
The following table shows the list of subcommands:
Subcommand | Description |
apply | Creates a node or modifies an existing node. |
destroy | Deletes a node. |
Plan | Performs terraform plan activity. |
refresh | Performs terraform refresh activity. |
Validate | Performs resource validation. |
list-templates | Displays all available terraform templates. |
exec | Executes other commands such as az, aws, etc. |
output | Displays the output of terraform output command. |
To know more options of each subcommand, invoke the help by executing the following command.
./deploy-terraform.sh <subcommand> -h|--help
Option | Expansion | Description |
-p | --provider | Specifies name of cloud provider such as AWS or Azure. |
-tn | --template-name | Specifies name of terraform template. |
-i | --input-file | Specifies input variables file for terraform. |
-as | --aws-secret-access-key | Specifies AWS secret access key. |
-ak | --aws-acess-key-id | Specifies AWS access key. |
-ast | --aws-session-token | Specifies session token provided by AWS. |
-r | --region aws | Specifies AWS region. |
-n | --volterra-cluster-name | Specifies the cluster name. |
-au | --azure-username | Specifies the azure user. |
-ac | --azure-client-id | Specifies azure client ID. |
-azc | --azure-client-secret | Specifies azure client access secret. |
-at | --azure-tenant-id | Specifies azure user tenant. |
-f | --force | Enables the -auto-approve option for terraform command. |
-d | --develop | Enables develop mode which mounts the local code to the container. |
--container-img | Enables the usage of the specified container image. | |
--tf-version | Specifies the terraform version. Supported versions are 0.11 and 0.12. The default version is 0.11. |
Examples
The following example displays a list of azure accounts in tabular format:
./deploy-terraform.sh exec az account list --output table
The following example displays the caller identity of the associated AWS account:
./deploy-terraform.sh exec aws sts get-caller-identity
The following example displays the deployment details:
./deploy-terraform.sh output -n <name of deployment>
Volterra terraform provider can used to configure Volterra infrastructure objects using Volterra API's.
Volterra terraform provider supports authenticating to Volterra using API Credential P12 file. Learn more on how to generate api certificate.
Example Usage
# Configure Volterra Provider
provider "volterra" {
api_p12_file = "/path/to/api_credential.p12"
url = "<tenant_name>.console.ves.volterra.io/api"
# Create a namespace
resource "volterra_namespace" "devops" {
name = "example-devops"
Argument Reference
The following arguments are supported
api_p12_file
- API credential p12 file path. Either api_p12_file or (api_cert and api_key) must be givenapi_cert
- API certificate file path.api_key
- API certificate private key file pathurl
- Tenant API url file path (Required)timeout
- Volterra api call timeout, by default its 10 seconds
When using api_p12_file
, password for the p12 file must be passed as the environment variable VES_P12_PASSWORD
Volterra objects creation, read, update and deletion functionalities are defined as part of terraform provider resources. Internally it maps terraform lifecycle operation to Volterra’s public API operations.
Namespace
Example Usage
Argument reference
annotations
- Annotations is an unstructured key value map stored with a resource that may be set by external tools to store and retrieve arbitrary metadata. They are not queryable and should be preserved when modifying objects (Optional) -
description
- Human readable description for the object -
disable
- A value of true will administratively disable the object -
labels
- Map of string keys and values that can be used to organize and categorize (scope and select) objects as chosen by the user. Values specified here will be used by selector expression -
name
- Name of the namespace object (Required)
Attribute Reference
uid
orid
- ID of Namespace objecttenant_name
- Tenant name
Origin Pool
Example Usage
# create namespace
# create origin pool in example-devops namespace
resource "volterra_origin_pool" "example_op" {
name = "apache-org"
namespace = "example-devops"
loadbalancer_algorithm = "ROUND_ROBIN"
origin_servers {
choice {
public_name {
dns_name = "apache.org"
port = 80
Argument Reference
annotations
description
disable
labels
name
- Name of the origin_pool object (Required) -
namespace
- This defines the workspace within which each the configuration object is to be created. Must be a DNS_LABEL format (Required)
NOTE: The following list explains only those arguments that are used in the above example:
origin_servers.choice.public_name.dns_name
- Specify origin server with public DNS name -
- Different load balancing algorithms supported When a connection to an endpoint in an upstream cluster is required, the load balancer uses loadbalancer_algorithm to determine which host is selected. Valid values areROUND_ROBIN
,LEAST_REQUEST
,RING_HASH
andRANDOM
port
- on which the service is available
HTTP Loadbalancer
Example Usage
# create namespace
name = "apache-org"
origin_servers {
choice {
public_name {
port = 80
# create http loadbalancer in example-devops namespace
resource "volterra_http_loadbalancer" "volt_apache" {
name = "volt-apache"
add_location = true
advertise_choice {
advertise_on_public_default_vip = true
default_route_pools {
pool_choice {
pool {
name = "apache-org"
tenant = volterra_namespace.devops.tenant_name
domains = ["volt-apache.helloclouds.app"]
loadbalancer_type {
https_auto_cert {
http_redirect = true
Argument Reference
annotations
description
disable
labels
name
- Name of the http_loadbalancer object (Required) -
namespace
add_location
- Appends header x-volterra-location = in responses. This configuration is ignored on CE sites. -
domains
- A list of domains (host/authority header) that will be matched to loadbalancer. Wildcard hosts are supported in the suffix or prefix form -
default_route_pools.pool_choice.pool
- Select the reference pool objectname
- name of the origin poolnamespace
- namespace of the origin pool objecttenant
- tenant where the namespace exists
loadbalancer_type.https_auto_cert.http_redirect
- Enable http auto cert and http_redirect
