Encrypt VMware Site Disk
Objective
This document provides instructions on how to configure VMware CE Site Virtual Machine Disk (VMDK) encryption using vSphere client. This helps to keep the data on disk encrypted at rest, aiding in securely managing your CE.
Note: To learn more about VMware disk encryption, see the VMware documentation.
Prerequisites
VMware vSphere Hypervisor (ESXi) 7.0 or later. The examples in this document are based on version 7.0.0.
A vSphere Key Provider is required to be configured. See VMware documentation for configuration instructions.
Encrypt CE Disk
You can enable disk encryption either during the VM creation or after the VM is created. Follow the chapters below for instructions on both procedures.
Enable Disk Encryption During VMware VM Creation
During VM creation, as described in the VMware Site Creation document, for storage selection, select
Encrypt this virtual machine (Requires Key Management Server)
Select a policy for the
VM Storage Policy
field. -
Click
Next
Note: By default, the
VM Storage Policy
is set to a default data storage policy. Click on it to see a drop-down list with the policies you created.
Enable Disk Encryption for Existing VMware VM using vSphere
Step 1: Power off the VM.
Log in using your vSphere client.
Right-click on your virtual machine, and then select
Power off
Step 2: Configure storage policies to enable disk encryption.
- Click the
Configure
tab.
Figure: Open Configure Tag
- Click
Policies
Figure: Open Policies
- Click
EDIT VM STORAGE POLICIES
Figure: Edit Storage Policies
- Select your Encryption policy under
VM storage policy
. The default selection isVM Encryption Policy
Figure: Select Storage Policies
- Click
OK
Figure: Click OK
Step 3: Power on the VM.
Power on
Concepts
- System Overview
- Core Concepts
- Networking
- F5 Distributed Cloud - Customer Edge
- F5 Distributed Cloud Site
