Create Multi Node KVM Site on Equinix
On This Page:
Objective
This document provides instructions on how to install an F5® Distributed Cloud Services multi-node Kernel-based Virtual Machine (KVM) site on Equinix Metal service. To learn more about sites, see Site.
Using the instructions provided in this document, you can deploy three Equinix bare metal servers with CentOS as the host operating system, create virtual machines on them, install Distributed Cloud Services software on those VMs, and then register the nodes into a multi-node cluster site.
Prerequisites
A Distributed Cloud Services account. If you do not have an account, see Create an Account.
An Equinix Bare Metal Account. For more information, see Equinix Documentation.
Resources required per site: Minimum 4 vCPUs and 14 GB RAM.
Configuration
In case of this deployment, the F5® Distributed Cloud Mesh (Mesh) nodes require two interfaces attached. The first interface is the outside interface through which services running on the node can connect to the Internet. The second interface is the inside interface whose IP address is the default gateway IP address for all the application workloads and services present in the private subnets.
This image provides a high level view of the network topology:
Deploy Equinix Metal Servers
In case of deploying Mesh nodes on Equinix, first deploy three on-demand Equinix bare metal servers.
Note: Equinix Metal supports various types of server instance sizes and different CPU architectures. However, you can only deploy Mesh on x86 CPU architecture and not on Atom or ARM architectures.
Also, the following Equinix Metal instance sizes do not support the Layer 2 functionality required for a successful deployment:
- t1.small.x86
- c1.small.x86
- X1.small.x86
Perform the following steps:
Step 1: Start creating Equinix Metal Servers.
Log into the Equinix Console with your account credentials.
Click
Servers
>Choose Deploy Type
>Deploy On Demand Servers
- Select a location and a server type.
Step 2: Set operating system and the number of servers.
Select
CentOS
and chooseCentOS 7
as the operating system version. -
Use the
button to set three servers and enter names for each of them.
Step 3: Optionally, add the user data and start deploying the servers.
- Prepare the user data for configuring packages. The following is a sample:
#cloud-config
package_upgrade: true
packages:
- qemu-kvm
- qemu-img
- virt-manager
- libvirt
- libvirt-python
- libvirt-client
- virt-install
- virt-viewer
- bridge-utils
runcmd:
- systemctl start libvirtd
- virsh net-undefine default
- virsh net-destroy default
Enable the
Add User Data
option and paste the configuration you prepared. -
Click the
Deploy Now
button to start deploying the servers.
Step 4: Verify that the servers are deployed.
After successful deployment, the Servers
page displays the list of metal servers deployed.
Step 5: Request elastic IP block.
After creating the servers, you are required to configure IP addresses by obtaining an elastic IP address block.
- Click
IPs & Networks
>IPs
Select
Public IPv4
, choose a location, choose a quantity, and then clickSubmit Request
Repeat for the
Public IPv6
option.
- Verify the IP addresses are assigned in the
PROJECT IP ADDRESSES
tab.
Step 6: Create VLANs.
The dual network interface controller (NIC) Mesh installation requires two VLANs, one for the internal interface and one for the external interface.
Click
IPs & Networks
>Layer 2
Click
Add New VLAN
Set the description to indicate it is an internal VLAN and click
Add
Repeat the previous step to create another VLAN and set the description to indicate that it is an external VLAN.
Verify the created VLANs.
Convert Server Networking and Assign IPs/VLANs
When an Equinix Metal server is first deployed, there is a single-bonded interface. To support the dual NIC Mesh installation, the server networking type needs to be converted to Hybrid Bonded
. By converting to hybrid bonded, the VLANs created in the previous section can be assigned to the bare metal instance.
Step 1: Convert networking to hybrid bonded mode.
- Go to the
Servers
page and click on a server for which the networking is required to be converted.
The server overview page displays the networking information:
Select
Network
from the left menu to open the network page. -
Click
Convert to Other Network Type
Select
Hybrid
in the network type selection window. -
Select
Bonded
in the options and select one of the VLANs to assign.
Note: You can select any of the created VLANs. The second VLAN will be assigned in the next step. Therefore, the order of configuration does not matter.
- Click
ASSIGN NEW VLAN & CONVERT TO HYBRID NETWORKING
Step 2: Assign second VLAN to the bare metal instance.
- In the
Network
page, go to theLayer 2
section and clickAdd New Vlan
- In the
Add New Vlan
window, select the other VLAN in theNetwork
field and clickAdd
Step 3: Add elastic IP addresses to the bare metal instances.
Each metal instance requires two elastic IP addresses, one IP address for the network bridge interface and another for the Mesh external interface. To use an elastic IP address, it must be assigned to the metal instance.
After planning your address scheme, perform the following:
- From the Elastic IP block that was allocated in the previous section, assign two
/32
addresses.
In this example, the allocated IP block is 147.28.142.240/29 and the first or last IP addresses are not used, as they represent the network and broadcast addresses.
The following table shows the sample IP addresses this example sets:
Metal Instance | Bridge IP Address | Distributed Cloud Services External IP Address |
VoltMesh-01 | 147.28.142.241 | 147.28.142.242 |
VoltMesh-02 | 147.28.142.243 | 147.28.142.244 |
VoltMesh-03 | 147.28.142.245 | 147.28.142.246 |
In the
Network
page for your server, clickAssign New Elastic
in theElastic IPs
section. -
In the
Add Elastic IP
window, selectPublic IPv4
from theAddress Type
menu. -
Select an option from the
Block
menu. -
Select
/32
from theLength
menu. -
Select an address from the
Address/Range
menu. -
Click
Add
Repeat the above steps to add another IP address.
From the
SERVER ACTIONS
menu, selectREBOOT
to reboot and apply the changes.
- Repeat the steps above for all your bare metal instances.
Deploy Site on Equinix Metal Servers
Deploying a multi-node site includes installing Mesh node on each of the metal servers. This involves configuring KVM on the instances, creating VMs with Mesh node images, performing post-installation configuration, and registering the Mesh nodes.
Configure KVM on Metal Instances
Configure the KVM hypervisor to support installation of Mesh software. Repeat this process for each bare metal instance.
Step 1: Connect to your instances using SSH.
- To SSH into the first metal instance, click
>SSH Info
- Click
Copy
to copy the SSH command displayed on the screen.
- Using your preferred SSH client, log into the server as root.
Step 2: Edit system configuration to support Mesh cluster operation.
- Open the
sysctl.conf
file for editing:
vi /etc/sysctl.conf
- Add the following contents to the end of the file and save the changes:
vm.nr_hugepages = 1200
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-ip6tables = 0
net.bridge.bridge-nf-call-iptables = 0
net.bridge.bridge-nf-call-arptables = 0
- Load the bridge filter module:
modprobe br_netfilter
- Apply the changes:
sysctl -p
Step 3: Download Mesh KVM software.
- Copy the link to the latest software from the KVM Images page and use the
wget
command to download the image. The following is a sample command:
wget -O /var/lib/libvirt/images/volterra.iso https://vesio.blob.core.windows.net/dev/images/centos/7.2009.10-202106210938/vsb-ves-ce-certifiedhw-generic-production-centos-7.2009.10-202106210938.1624275431.iso
- Wait for the download to complete. The download progress is indicated, and after completion, the command prompt is returned.
Step 4: Create a disk image for the Mesh node.
Enter the following command:
qemu-img create /var/lib/libvirt/images/disk1.qcow2 30G
Step 5: Define KVM internal and external network interfaces.
Define the internal and external KVM network interfaces and apply configuration parameters. The format of the device name is bond0.<VLAN ID>
. In this example, the VLAN IDs assigned to the Distributed Cloud Services internal and external VLANs are 1000 and 1001, respectively.
- Create the internal VLAN interface file for editing:
vi /etc/sysconfig/network-scripts/ifcfg-bond0.1000
- Add the following values and save the file:
DEVICE=bond0.1000
ONBOOT=yes
BOOTPROTO=none
BRIDGE=br0
VLAN=yes
- Create the external VLAN interface:
vi /etc/sysconfig/network-scripts/ifcfg-bond0.1001
DEVICE=bond0.1001
ONBOOT=yes
BOOTPROTO=none
BRIDGE=br1
VLAN=yes
Step 6: Configure internal VLAN interface network bridge IP addresses.
Define the Distributed Cloud Services internal VLAN interface network bridge IP addresses. The external Distributed Cloud Services interface use public IP addresses. For internal interface, the RFC1918 private addresses are used. This step configures only the bridge IP address for each instance.
Note: The internal IP address configuration is performed within F5® Distributed Cloud Console (Console) during a later step.
You can choose an IP address scheme per your choice for internal addressing, except the IP address space used by the bond0:0
interface. You can find the IP used by the bond0:0
interface by running the ip addr
command.
In this example, the 192.168.100.0/24
address block is used. The following is the allocation scheme for this example:
Metal Instance | Bridge IP Address | Distributed Cloud Services Internal IP Address |
VoltMesh-01 | 192.168.100.10 | 192.168.100.11 |
VoltMesh-02 | 192.168.100.20 | 192.168.100.21 |
VoltMesh-03 | 192.168.100.30 | 192.168.100.31 |
Note: Bridge IP Address is the
SiteLocalInside
gateway and Distributed Cloud Services internal IP address is theSiteLocalInside
IP prefix within Console.
- Create and open the internal bridge interface file for editing:
vi /etc/sysconfig/network-scripts/ifcfg-br0
- Add
DNS1
,DNS2
,IPADDR
, andPREFIX
settings and save the file. The following is a sample for the first metal instance:
DEVICE=br0
STP=no
TYPE=Bridge
BOOTPROTO=none
DEFROUTE=yes
NAME=br0
ONBOOT=yes
DNS1=8.8.8.8
DNS2=8.8.4.4
IPADDR=192.168.100.10
PREFIX=24
- Repeat the steps for each metal instance with the appropriate IP address based on your address scheme.
Step 7: Configure external VLAN interface network bridge IP addresses.
Define the Distributed Cloud Services external VLAN network bridge IP addresses. We recommend you use the IP address pattern as shown in the example below. Ensure not to use the first and last IP addresses in the /29
address range.
This example uses the elastic IP block 147.28.142.240/29
Note: This step configures only the bridge IP address for each instance. External IP address configuration is performed within Console during a later step.
The following is the scheme used for this example:
Note: Use the Elastic IP addresses from the block obtained in the Deploy Equinix Metal Servers chapter. The Bridge IP address is
SiteLocal GW
and the Distributed Cloud Services external IP address is theSiteLocal IP prefix
within Console.
vi /etc/sysconfig/network-scripts/ifcfg-br1
- Add
DNS1
,DNS2
,IPADDR
, andPREFIX
settings and save the file. The following is a sample for first metal instance:
DEVICE=br1
STP=no
TYPE=Bridge
BOOTPROTO=none
DEFROUTE=yes
NAME=br1
ONBOOT=yes
DNS1=8.8.8.8
DNS2=8.8.4.4
IPADDR=147.28.142.241
PREFIX=29
Reboot the metal instances and ping the elastic IP addresses to verify connectivity.
Create and Configure Mesh Virtual Machines
Create a Mesh virtual machine (VM), assign IP addresses to the internal and external interfaces, and configure the Mesh settings.
Step 1: Create Mesh VM using the KVM CLI.
- Enter the following command:
virt-install --name volterra \
--ram 16384 --vcpus=8 \
--os-variant=centos7.0 \
--network bridge=br1,model=virtio \
--network bridge=br0,model=virtio \
--accelerate \
--disk path=/var/lib/libvirt/images/disk1.qcow2,bus=virtio,cache=none,size=64 \
--cdrom /var/lib/libvirt/images/volterra.iso \
--noautoconsole --noreboot
- To start the VM, enter the following command:
virsh start volterra
- To start the VM automatically when the underlying host OS is started, enter the following command:
virsh autostart volterra
After the VM is started, use the KVM console to connect to it. The ID of the VM assigned by the KVM is required for this.
To obtain the ID assigned to the VM, enter the following command:
virsh list
Step 2: Connect to the local Console.
- Connect to the local console of the VM using the VM ID obtained in the previous step. The following is a sample command:
virsh console 1
- At the login prompt, use
admin
as the username andVolterra123
as the password.
- After logging in for the first time, choose a new password. Passwords must be at least 8 characters and include at least one upper case letter.
Step 3: Configure Mesh external interface.
Use the tab key to open the configuration menu and navigate to
configure-network
, and then press the enter key to start network configuration. -
Use the arrow keys to navigate to the
OUTSIDE
option and press the space bar to select.
- On the screen that follows, populate the fields as shown in the following image:
- To confirm the changes, type
y
and then press the enter key.
Step 4: Configure Mesh internal interface.
configure-network
and press enter key to start network configuration. -
INSIDE
Ensure that you set the primary interface as
OUTSIDE
y
Step 5: Create or obtain a site token.
To configure Mesh and register your site, a site token is required. You can create a new token or use an existing token. This example shows steps to create a new token.
Log into Console.
Click
Cloud and Edge Sites
Click
Manage
>Site Management
>Site Tokens
Click
Add site token
Enter a name for the token and click
Add site token
Note down the generated token code under the
UID
column for your token.
Step 6: Configure other required Mesh settings.
At this point, you can either connect using the KVM console or use SSH to connect. In case of SSH, you can use the elastic IP address you configured in previous section. This example shows connecting using SSH.
- Connect to the Mesh node using SSH and the elastic IP address for your instance.
configure
and press the enter key to begin configuration. -
For
What is your token
andWhat is your site name?
, enter the same name and token for all nodes. Use the token created in the previous step. -
y
and then press the enter key. Your node will start to connect to Console for registration.
Step 7: Register your site.
Click
Manage
>Site Management
>Registrations
Choose your site from the list of sites displayed under the
Pending Registrations
tab. -
Click the blue checkmark.
On the page that opens, set the
Cluster Size
to3
. Make sure that you set each node to the same cluster size. -
Click
Save and Exit
to complete the registration process. -
Repeat the above steps for each of the remaining nodes.
Note: It may take a few minutes for the registration process to complete and the site to change to
ONLINE
