Manage USB Devices Using Fleet
On This Page:
Objective
This guide provides instructions on how to manage USB devices for your sites using fleet configuration in the F5® Distributed Cloud Console (Console). See Fleet for conceptual details of the fleet.
You can enable or disable access to USB devices for your sites via the fleet configuration. By default, all USB devices are denied in the fleet, and you can allow all or attach USB device policies to manage specific devices. You can also create a USB device policy from within the fleet configuration.
Using the instructions in this guide, you can update fleet configuration to enable or disable access to all or specific USB devices for your sites that are part of the fleet.
Prerequisites
An F5® Distributed Cloud Services Account is required. If you do not have an account, see Create an Account.
One or more sites. See Site Management for more information.
A fleet with the sites added to this fleet. See Create a Fleet for more information.
Configuration
The following video shows creating a fleet with the required network configuration and applying to your gateways:
Apply USB Device Policy Using Fleet
Log into Console and perform the following:
Step 1: Navigate to fleets and start editing fleet configuration.
- In Console, click
Cloud and Edge Sites
- Click
Manage
>Site Management
>Fleets
- Click
>Manage Configuration
for the fleet you want to manage the USB devices.
- Click
Edit Configuration
Step 2: Start configuring the USB device policy.
- In the
Advanced Configuration
section, enable theShow Advanced Fields
option.
Select an option from the
USB Device Policy
menu and perform configuration per the following guidelines:-
Select
Deny All USB Devices
to deny all USB devices for your sites. This option is selected by default. -
Select
Allow All USB Devices
to allow all USB devices for your sites. -
Select
USB Device Policy
to apply an existing USB device policy or create a new one.
This example creates a new USB device policy from within fleet configuration and applies it to a fleet.
Click
USB Device Policy
From the
USB Device Policy
menu, clickCreate new usb policy
. This opens the USB device policy creation form.
Step 3: Create a USB device policy.
In the
Metadata
section, enter a name for the USB device policy. -
Optionally, add a description and labels.
In the
Allowed USB devices
section, clickConfigure
Click
Add Item
Configure the fields per the following guidelines:
In the
iSerialNumber
field, enter an index for the serial number for your device. -
In the
Vendor ID
field, enter the device vendor identifier. -
In the
Product ID
field, enter the device product identifier assigned by the manufacturer. -
In the
Class
field, enter the device class. -
In the
Subclass
field, enter the device subclass. -
In the
Protocol
field, enter the protocol for this device. -
After you finish, click
Add Item
Click
Apply
. You can add more than one device using theAdd Item
option. -
Click
Continue
Click
Save and Exit
To obtain the USB device properties using the site dashboard:
Navigate to
Sites
>Site List
Click on your site to open its dashboard.
Click on the
Tools
tab. -
Select
Show USB devices
option from theSelect tool
field. -
Select a node from the list under the
Node name
field.
Step 4: Complete updating the fleet configuration.
In the
Enable Default Fleet Config Download
option. -
Click on the
checkbox. -
Click
Save and Exit
to apply the USB device policy to the sites that are part of the fleet.
