Configure Multi-Node Site Network Using Fleet
On This Page:
Objective
This guide provides instructions on how to configure the networking configuration for each node in a multi-node site using F5® Distributed Cloud Services Fleet. All the multi-node sites belonging to the Fleet will be configured equally, and you can further enhance the security by adding a network firewall to the Fleet, to ensure consistent security policy across all the sites in the Fleet. These instructions cover the following:
IP address management of outgoing interfaces (toward the Internet).
IP address management of interfaces toward inside networks.
Segmentation of subnets using virtual local area networks (VLANs).
For information on how to use networking, see Networking.
For information on how to create a Fleet, see Create a Fleet.
For information on how to create and manage sites, see Site Management.
Prerequisites
A Distributed Cloud Services Account. If you do not have an account, see Create an Account.
A multi-node site.
Configuration Diagram
The following diagram shows an example topology for the use case presented in this guide:
The example in this topology sets up a multi-node site as a network gateway for inside networks. The gateway has three master nodes and a Layer 2 switch with three VLANs for segmentation of employee workstations, development servers, and test servers. To set up this topology, you need to configure the following in the Fleet object:
Two virtual networks: one outside network and one inside network. This example creates inside and outside networks as part of Fleet.
Set up the following network interfaces:
- Dedicated Interfaces on the Site Local Outside (WAN).
Note: The IP addressing must be static or a fixed DHCP lease from an upstream DHCP server. Changing of SLO IP addresses in a multi-cluster setup is currently not supported.
Ethernet Interface for the Site Local Inside Network. We will configure Static Node Address, a DHCP Server, and DHCP Fixed Leases for internal hosts such as printers.
Set up a site local breakout from the Inside to Outside network using the network connector with SNAT.
Finally, apply the Fleet with the above objects to your multi-node site to enable the network connectivity.
Create Fleet
Step 1: Start Fleet configuration.
Log into F5® Distributed Cloud Console (Console).
Click
Multi-Cloud Network Connect
- Click
Manage
>Site Management
>Fleets
- Click
Add Fleet
Step 2: Add your Fleet name and metadata.
In the
Metadata
section, enter a mandatory Fleet name in theName
field. -
Optionally, select a label and enter a short description.
Step 3: Configure your Fleet label, virtual networks, and software versions.
In the
Fleet Configuration
section, enter a mandatory value for the Fleet label in theFleet Label Value
field. -
Configure the following optional fields:
Select an outside virtual network from the
Outside (Site Local) Virtual Network
menu. To create a new network, clickAdd Item
. In the page that appears, configure the fields. After you finish, clickContinue
Select an inside virtual network from the
Site Local Inside Virtual Network
In the
Software Version
field, enter a software version. -
In the
Operating System Version
field, enter an operating system version.
Step 4: Select or create network interfaces for the sites in your Fleet.
Step 4.1: Add and configure a new bond device.
From the
Select Bond Configuration
menu, select if you want to configure a new bond interface withConfigure Bond Interfaces
Click
Add Item
From the
Bond Device Name
menu, clickSee Common Values
. Select a value from the list displayed.
From the
Member Ethernet Devices
. Select a value from the options displayed. You can add more devices using theAdd Item
option. -
From the
Select Bond Mode
menu, select how the bonding occurs. If you selectLACP (802.3ad)
, optionally enter a packet interval value in theLACP Packet Interval
field. The default value is30
Click
Apply
Step 4.2: Configure non-bond interfaces.
From the
Select Interface Config
menu, selectList of Interfaces
From the
List of Interfaces
menu, selectAdd Item
In the
Name
field, enter an interface name. -
From the
Interface Config Type
menu, selectDedicated Interface
From the
Interface Device
, and then selecteth0
From the
Select Configuration for Cluster or Specific Node
menu, selectCluster, All Node of the site
From the
Select Primary Interface
menu, confirm whether this interface is primary. -
Click
Continue
Note: WAN IP address configuration is out of scope for this documentation.
Step 4.3: Configure inside network interface for a development network.
You can configure inside network interfaces using the following methods:
Interface with DHCP Server: This enables you to specify the DHCP pool settings. You can also statically map IP address based on hostname or MAC addresses.
Interface with DHCP Client: This enables the interface to obtain IP addresses from a DHCP server.
Interface with Static Mapping: This enables you to manually assign IP addresses to nodes.
Interfaces with DHCP Server Method:
From the
From the
List of Interfaces
Enter a name in the
Name
field for the development subnetwork. -
From the
menu, selectEthernet interface
Click
Configure
From the
Ethernet Device
. Select a value from the displayed list. -
From the
Select Untagged or VLAN tagged
menu, selectVLAN Id
and then enter aVLAN Id
From the
Select Interface Address Method
menu, selectDHCP server
and then clickConfigure
Under the
DHCP Networks, Pools, Gateway
section, clickConfigure
From the
Select Network Prefix Method
menu, selectNetwork Prefix
and then enter a network prefix. -
From the
DHCP Pool Settings
menu, selectInclude IP Addresses from DHCP Pools
Click
Add Item
and then enter theStarting IP
andEnding IP
per your choice. -
Set the default gateway and DNS server addresses per your choice.
Click
Apply
In the
Interface Address
section, enableShow Advanced Fields
From the
Select Interface Addressing
menu, selectConfigured
Click
Add Item
Enter the site node, and then enter an IPv4 address. You can add more static mappings using the
Add Item
option. This is the interface configuration from the master nodes toward the development subnet. -
In the
Fixed IP Assignments for Clients
section, add the MAC address to IPv4 mappings. You can add more static mappings using theAdd Item
option. -
Click
Apply
Click
Apply
to create the interface and add to your Fleet. -
Click
Continue
Interfaces with Static Mapping Method:
From the
Select Interface Configuration
From the
List of Interfaces
Enter a name in the
Name
From the
Click
Configure
From the
Ethernet Device
, and then select an option. -
From the
menu, selectCluster, All Nodes of the Site
From the
menu, selectVLAN Id
Enable the
option. -
From the
menu, selectStatic IP
From the
Select Static IP Configuration
menu, selectSpecific Node
Enter the
IP address/Prefix Length
and optionally addDefault Gateway
In the
Virtual Network
section, selectSite Local Network Inside
from theSelect Virtual Network
menu. -
From the
, select whether this interface is a primary interface. -
Click
Apply
Click
Continue
Step 4.4: Configure inside network interface toward workstations and test server subnetworks.
Follow the same steps as that of Step 4.3 above, with the IP addresses of the node interfaces toward the other two subnetworks and DHCP pool settings for the clients.
The following instructions show interface configuration in the DHCP server mode. Static mapping is not shown. If you are using static mapping, follow the instructions in the Interfaces with Static Mapping Method subsection in Step 4.3. Create interfaces for each VLAN with node to IP address mapping. For this section example, there are three VLANs and three nodes, so three interface objects are required with each interface consisting of three IP mappings.
DHCP network settings for VLAN 191 (interface name subnet-clients-vlan191
Static mappings for VLAN 191:
DHCP network settings for VLAN 192 (interface name subnet-vmware-vlan192
Static mappings for VLAN 192:
Step 5: Configure network connectors.
To select an existing network connector:
Click
Select Network Connector
From the list that appears, find and select the network connector, and then click
To create a new connector, click
Add new Network Connector
Complete the configuration using the instructions provided at Network Connectors.
Step 6: Complete Fleet network creation.
Click Save and Exit
Apply Fleet Label to Site
After your Fleet is created and configured, you will need to apply its label to your multi-node site.
Step 1: Navigate to your Site.
In
, clickSites
, and then clickSite List
Find your site, click
and then clickManage Configuration
Click
Edit Configuration
to edit your site properties.
Step 2: Apply the Fleet label.
In the
Labels
box form, start by typing “fleet” and you will see the key-value pairves.io/fleet
. Select this key-value pair. -
Type the name of your Fleet label, and then select it.
Step 3: Save the configuration.
Click Save changes
