Create Secure Mesh Site
On This Page:
Objective
This document provides instructions on how to install F5® Distributed Cloud single-node or multi-node F5 Distributed Cloud Secure Mesh Sites on devices such as Baremetal or Virtual Machines (VM) running on KVM or VMware. A Secure Mesh Site is a Distributed Cloud Customer Edge (CE) Site engineered specifically for the purpose of providing ease for users to create Sites with non-cloud, F5® Distributed Cloud Mesh (Mesh) certified hardware. To know more about Distributed Cloud sites, see Site.
Using the instructions provided in this document, you can create a single-node or multi-node Secure Mesh Site object in the F5® Distributed Cloud Console, perform required configurations such as interface configuration, install the image to the respective device or VM, and register the Site to complete Site deployment.
Note: After deployment, Secure Mesh Site functions similar to other non-cloud Mesh Sites but as opposed to other Sites, Secure Mesh Site makes it easier to manage the Site and perform advanced configurations.
Secure Mesh Site vs Other Mesh Sites
The Secure Mesh Site makes it easier to plan, choose infrastructure settings such as interfaces before installation, and also perform advanced configuration steps that are not available using Fleet or regular Site management functionalities. The following list presents the benefits of Secure Mesh Site over other non-cloud Mesh Sites:
- Provides ease of operation to configure Sites with non-cloud, Mesh certified hardware.
Note: This is similar to App Stack Sites for deploying Sites with App Stack functionality. See App Stack Site for more information.
Prevents common errors while configuring Mesh Sites, by simplifying the form and enhancing validation in cases such as the following:
- Choosing correct hardware when configuring inside interface from Global Controller
- Misconfiguration of in DHCP server on interfaces
Expose features that are not available in Fleet and Site configuration, for example:
- Offline Survivability
- Multi-Tunnel Site Mesh Group configuration for public and private IPs
Note: The following are not supported for Secure Mesh Site:
- Storage Interfaces, Devices and Classes
- Site Local K8s API access
- USB devices
- VM support (running VMs on the Site)
Prerequisites
An F5 Distributed Cloud Account. If you do not have an account, see Create an Account.
One or more devices or VMs consisting of interfaces with internet reachability for Site installation.
Resources required per node: Minimum 4 vCPUs and 14 GB RAM.
Internet Control Message Protocol (ICMP) needs to be opened between the CE nodes on the Site Local Outside (SLO) interfaces. This is needed to ensure intra-cluster communication checks.
Deploy Site
Perform the steps provided in the following chapters to deploy a Secure Mesh Site.
Create Site Token
Create a site token or use an existing token. If you are configuring a multi-node site, use the same token for all nodes.
Step 1: Navigate to site tokens page.
Log into F5® Distributed Cloud Console.
Click
Multi-Cloud Network Connect
Select
Manage
>Site Management
>Site Tokens
Click
Add Site Token
to create a new token.
Step 2: Generate a new site token.
In the
Name
field, enter the token name. -
In the
Description
field, enter a description for the token. -
Click
Save and Exit
Step 3: Note down the new token.
Find the token previously created or choose an existing token from the list of tokens displayed.
Click
to expand the token details in JSON format and note down the value of theuid
field.
Create Secure Mesh Site Object
Log into F5 Distributed Cloud Console and perform the following steps:
Step 1: Start creating an Secure Mesh Site object.
In
service, navigate toManage
>Site Management
>Secure Mesh Sites
Select
Add Secure Mesh Site
to open the Secure Mesh Site configuration form.
Enter a name in the
Metadata
section for your Secure Mesh Site object. -
Optionally, select labels and add a description.
Step 2: Set the fields for the basic configuration section.
From the
Generic Server Certified Hardware
menu, select an option. Theisv-8000-series-voltmesh
is selected by default. -
Enter the names of the master nodes in the
List of Master Nodes
field. SelectAdd item
to add more than one entry. Only a single node or 3 master nodes are supported.
Note: Enter the public IP in the
Public IP
field for the master nodes. These IP addresses are only used when a Site is part of a Site Mesh Group, and you have selected theSite Mesh Group Connection Via Public Ip
option forSite Mesh Group Connection Type
field as shown in Step 4.6.
Optionally, enter the names of worker nodes in the
List of Worker Nodes
to add more than one entry. -
Optionally, enter the following fields:
Geographical Address: This derives geographical coordinates.
Coordinates: Latitude and longitude.
Step 3: Optionally, configure bond interfaces.
In the Bond Configuration
section, perform the following:
From the
Select Bond Configuration
menu, selectConfigure Bond Interfaces
Select
Configure
to open bond interface configuration page. -
Select
Add Item
under theBond Devices List
field. -
Select on the
Bond Device Name
field and selectSee Common Values
. You can also type a custom name and clickAdd item
to set the device name while also adding it to the existing options. -
Select on the
Member Ethernet Devices
for the Ethernet device that is part of this bond. UseAdd item
option to add more devices. -
From the
Select Bond Mode
menu, select the bonding mode.LACP (802.3ad)
is selected by default for the bonding mode with the default LACP packet interval as 30 seconds. You can set the bond mode toActive/Backup
to set the bond members function in active and backup combination. -
Select
Add Item
Note: Use the
Add item
option in theBond Devices List
to add more than one bond device.
- Select
Apply
in theBond Devices
page to apply the bond configuration.
Step 4: Optionally, configure network settings.
The network configuration is applied with default settings. To customize network settings, do the following:
In the
Network Configuration
section, selectCustom Network Configuration
from theSelect to Configure Networking
menu. -
Select
View Configuration
to open the network configuration page and do the following:
Step 4.1: Configure site local network settings.
Site local network is applied with default configuration. Perform the following set of steps to apply custom configuration:
Select
Configure Site Local Network
from theSelect Configuration For Site Local Network
menu. -
Select
View Configuration
Optionally, set labels for the
Network Labels
field in theNetwork Metadata
section. -
Select
Manage Static Routes
from theManage Static Routes
menu. -
Select
Add Item
and perform the following:-
Enter IP prefixes for the
IP Prefixes
section. These prefixes will be mapped to the same next-hop and attributes. -
Select
IP Address
orInterface
orDefault Gateway
from theSelect Type of Next Hop
menu and specify IP address or interface accordingly. In the case ofInterface
, you can select an existing interface or create a new interface using the options for the interface field. -
Optionally, select one or more options for the
Attributes
field to set attributes for the static route. -
Select
Apply
Note: You can use
Add Item
button in theStatic Routes
section to add more than one static route.
DC Cluster Group
using the following guidelines:-
Select
Member of DC Cluster Group
from theSelect DC Cluster Group
menu. -
In the
field, select a DC cluster group. You can also selectCreate New DC Cluster Group
to create a new cluster group. Performing this adds this site to a DC cluster group, enabling full connectivity between the members of the group.
- Select
Apply
Note: For more information, see the Configure DC Cluster Group guide.
Step 4.2: Configure site local inside network settings.
Site local inside network is applied with default configuration. Perform the following set of steps to apply custom configuration:
Select
Configure Site Local Inside Network
menu. -
Select
Configure
Network Labels
section. -
Select
menu. -
Select
Add Item
IP Prefixes
Select
IP Address
orInterface
orDefault Gateway
Attributes
Select
Apply
Note: You can use
Add Item
DC Cluster Group
Select
menu. -
In the
Select
Apply
Step 4.3: Configure interface settings.
Bootstrap interface configuration is applied by default, and it is based on the certified hardware.
Perform the following to apply custom interface configuration:
Select
List of Interface
from theSelect Interface Configuration
menu. -
Click
Configure
. This opens another interface list configuration page. -
Select
Add Item
in theList of Interface
table. -
Optionally, enter an interface description and select labels.
Select an option from the
Interface Config Type
menu, and set one of the interface types using the following instructions:
Ethernet Interface:
Select
Ethernet Interface
and clickConfigure
. This opens Ethernet interface configuration page. -
Ethernet Device
menu usingSee Common Values
. You can also type a custom name to set the device name while also adding it to the existing options. -
Select
Cluster, All Nodes of the Site
orSpecific Node
from theSelect Configuration for Cluster or Specific Node
menu. In case of specific node, select the specific node from the displayed options of theSpecific Node
field. You can also type a custom name to set the device name while also adding it to the existing options. -
Select
Untagged
orVLAN Id
from theSelect Untagged or VLAN tagged
menu. In case of VLAN ID, enter the VLAN ID in theVLAN Id
field. -
Select Interface Address Method
menu in theIP Configuration
section. TheDHCP Client
is selected by default. In case you select a DHCP server, clickConfigure
and set the DHCP server configuration per the options displayed on the DHCP server configuration page and clickApply
. This example shows the interface as DHCP client for brevity. -
Select site local outside or site local inside network from the
Select Virtual Network
menu in theVirtual Network
section.Site Local Network (Outside)
Select if the interface is primary from the
Select Primary Interface
menu. Default is not a primary interface. Ensure that you set only one interface as primary. -
Select
Apply
Dedicated Interface:
Select
Dedicated Interface
from theInterface Config Type
menu. -
Select a device name from the
Interface Device
Select
orSpecific Node
menu. In case of specific node, select the specific node from the displayed options from theSpecific Node
menu. You can also type a custom name to set the device name while also adding it to the existing options. -
Select if the interface is primary in the
field. Default is not a primary interface. Ensure that you set only one interface as primary. -
Select
Add Item
Optionally, add more than one interface using the
Add item
option in theList of Interface
page. -
Select
Apply
Step 4.4: Configure security settings.
In case of security configuration, the firewall policies and forward policies are disabled by default.
In the Security Configuration
section, perform the following to apply network and forward policies:
Select
Active Enhanced Firewall Policies
from theFirewall Policy
menu and do the following:- Click
Configure
underEnhanced Firewall Policy
to switch to enhanced firewall policies list page. - Select an enhanced firewall policy object from the
drop-down. You can also create and apply a new enhanced firewall policy using theAdd Item
in the drop-down. - Use the
Add Item
button in the list page to add more than one enhanced firewall policy.
- Click
Select
Active Firewall Policies
menu and do the following:- Select a firewall policy object from the
Firewall Policy
drop-down. You can also create and apply a new firewall policy using theAdd item
option. - Use the
Add Item
button in the list section to add more than one firewall policy.
Select one of the following options from the
Forward Proxy
menu:-
Select
Enable Forward Proxy and Manage Policies
to apply specific forward proxy policies. Select a forward proxy policy from theForward Proxy Policies
drop-down. You can also create and apply a new forward proxy policy using theAdd Item
option. You can apply more than one forward proxy policy using theAdd item
option in the list section. -
Select
Enable Forward Proxy With Allow All Policy
to allow all requests.
Step 4.5: Configure global networks.
Enable
Show Advanced Fields
in theGlobal Connections
section. -
Select
Connect Global Networks
from theGlobal Network Connections
drop-down. -
Click
Add Item
in theGlobal Network Connections
section to open the global network connections page. -
Select one of the following for the
Select Network Connection Type
field:-
Direct, Site Local Inside to a Global Network
to connect site local inside network to global network. -
Direct, Site Local Outside to a Global Network
to connect site local outside network to global network.
Select a virtual global network from the
Global Virtual Network
drop-down. You can also create and apply a new virtual global network using theAdd Item
button. -
Click
Apply
to add global network connection to the Secure Mesh Site configuration.
Note: Use
Add Item
section to add more than one global network connection.
Step 4.6: Configure Site Mesh Group Connection Type.
The default connection type for incoming tunnels for Site Mesh Group (SMG) is via private IP. This option will use the Site Local Outside interface addresses for creating IPsec tunnels between two sites that are part of the SMG.
To change the connection type, select Site Mesh Group Connection Via Public Ip
from the Site Mesh Group Connection Type
field. This option will use the statically configured public IPs of each master node for creating IPsec between two sites that are part of the SMG.
Step 4.7: Configure advanced settings.
In the Advanced Configuration
section, do the following:
Select
Enable VRRP for VIP(s)
forVIP Advertisement Mode
. It is recommended to enable this and BGP if Outside VIP/Inside VIP are configured. -
Enter a value in milliseconds in the
Tunnel Dead Timeout (msec)
field to detect dead tunnels within this time. By default, 10000 milliseconds is set.
Click Apply
to add the custom network settings to the Secure Mesh Site configuration.
Step 5: Optionally, configure advanced features.
Do the following in the Advanced Configuration
section of Secure Mesh Site main configuration page:
Select
Enable Logs Streaming
from theLogs Streaming
drop-down and choose a log streaming object from the displayedEnable Logs Streaming
drop-down. This enables streaming of logs from the Site to the configured log receiver. For more information on log streaming configuration, see Logs Streaming. -
Select
F5XC Software Version
from theF5XC Software Version
field and enter a specific version in the enabledF5XC Software Version
field. By default, the latest software version is used. -
Select
Operating System Version
from theOperating System Version
field and enter a specific version in the enabledOperating System Version
field. By default, the latest OS version is used. -
Select
Custom Blocked Services Configuration
from theBlocked Services
field, clickAdd Item
to customize the service type and port you want to block, and clickApply
to add the custom blocking configuration. -
Select
Enable Offline Survivability Mode
from theOffline Survivability Mode
field to enable offline survivability mode.
- Select
L3 Mode Enhanced Performance
from thePerformance Mode
field and choose to enable or disable jumbo frames using theL3 Mode Enhanced Performance Options
field options. The L7 Enhanced Mode is enabled by default for the performance mode.
Step 6: Complete creating the Secure Mesh Site.
Select Save and Exit
to complete creating the Secure Mesh Site.
Note: You can also configure multiple interfaces for Virtual Machines (VM) or containers running in a K8s cluster within an Secure Mesh Site. For instructions, see Create Workloads with Multiple Network Interfaces.
Perform Site Registration
After creating the Secure Mesh Site object in Console, the Site shows up in Console with Waiting for Registration
status. Install the nodes and while doing initial configuration, ensure that the cluster name and host name for your nodes match with the Secure Mesh Site name and node name per the Basic Configuration
section of Secure Mesh Site object you configured. The initial configuration during node installation can be done either using SSH or using Site Local User Interface (UI).
Note: See Create VMware Site, Create KVM Site, and Create Baremetal Site for node installation instructions. See Site Local UI for information on using Site Local UI.
Perform registration per the following instructions:
Navigate to
Manage
>Site Management
>Registrations
Choose your site from the list of sites displayed under the
Pending Registrations
tab. -
Approve the option (blue checkmark).
Ensure that the cluster name and hostname is matching with those of the Secure Mesh Site.
Select
Accept
to complete registration and the Site turns online.
