Create KVM Site
On This Page:
- Objective
- Prerequisites
- Create Site Token
- Check for Virtualization Support
- Install Packages
- Configure HugePages
- Create a Virtual Network
- Install Node using Terminal
- Install Node Using the Virtual Machine Manager
- Post-Install Node Parameter Configuration
- Register the Site
- Single-Node Site Registration
- Multi-Node Site Registration
- Deploy Site Using Terraform
- Access Site Local UI
- Concepts
Objective
F5® Distributed Cloud Services support site deployment for a Kernel-based Virtual Machine (KVM) with libvirt. Use the instructions provided in this document to perform Distributed Cloud Services node installation on a server using a KVM with libvirt and to perform site registration on F5® Distributed Cloud Console (Console).
The following is a sample topology for the hypervisor and guest machine setup. The sample shows three guest virtual machines installed with F5 Distributed Cloud Services Site software running on the hypervisor host:
Prerequisites
A Distributed Cloud Services Account. If you do not have an account, see Create an Account.
A server supporting hardware virtualization. The KVM will only work if the server CPU has hardware virtualization support (Intel VT or AMD-V).
An operating system installed on the host:
Ubuntu 16.x/18.x/20.x
CentOS 7.x/RHEL 7.x
At least one interface with Internet reachability.
Distributed Cloud Services Node Zero Touch Provisioning requires Internet connectivity to Console.
A KVM image file. Click here to download.
Resources required per node: Minimum 4 vCPUs and 14 GB RAM.
45 GB is the minimum amount required for storage. However, if you are deploying an F5® Distributed Cloud App Stack Site, 100 GB is the recommended minimum amount of storage.
Internet Control Message Protocol (ICMP) needs to be opened between the CE nodes on the Site Local Outside (SLO) interfaces. This is needed to ensure intra-cluster communication checks.
By proceeding with the installation, download and/or access and use, as applicable, of the Distributed Cloud Services software, and/or Distributed Cloud Services platform, you acknowledge that you have read, understand, and agree to be bound by this agreement.
Create Site Token
Create a site token or use an existing token. If you are configuring a multi-node site, use the same token for all nodes.
Step 1: Navigate to site tokens page.
Log into F5® Distributed Cloud Console.
Click
Multi-Cloud Network Connect
Select
Manage
>Site Management
>Site Tokens
Click
Add Site Token
to create a new token.
Step 2: Generate a new site token.
In the
Name
field, enter the token name. -
In the
Description
field, enter a description for the token. -
Click
Save and Exit
Step 3: Note down the new token.
Find the token previously created or choose an existing token from the list of tokens displayed.
Click
to expand the token details in JSON format and note down the value of theuid
field.
Check if your system supports virtualization. The commands differ and are based on your particular Linux distribution.
Step 1: Check if virtualization is enabled on Ubuntu or RHEL.
Enter egrep '(vmx|svm)' /proc/cpuinfo | wc -l
. This command returns a non-zero number if virtualization is enabled.
Note: For Ubuntu, you may need to run the
sudo apt install cpu-checker
command prior to continuing. This action will install thecpu-checker
package.
Step 2: Verify if KVM acceleration is available on Ubuntu only.
Enter sudo kvm-ok
. This command returns a message that confirms that KVM acceleration can be used
sudo kvm-ok
Install Packages
Install all required packages. You need root privileges to update or install packages.
Install the required packages for Ubuntu
- Enter
sudo apt update
sudo apt update
- Enter
sudo apt install qemu qemu-kvm libvirt-daemon-system libvirt-clients bridge-utils virt-manager
Install the required packages for RHEL
- Enter
sudo yum update
sudo yum update
Confirm with
y
to perform the update. -
Enter
sudo yum install qemu-kvm qemu-img virt-manager libvirt libvirt-client virt-install virt-viewer libvirt-python bridge-utils
- Confirm with
y
to perform the installation.
Configure HugePages
Configure the HugePages to support increased virtual memory management that is greater than the default for your Linux system.
The steps below provide an example for setting the HugePages configuration for a cluster of three nodes. The required number of HugePages per node is 400.
Note: You can use a text editor, such as
vim
ornano
, to open the configuration file and make edits.
Step 1: Add HugePages configuration.
For the hypervisor host on Ubuntu, add the following in the Grub configuration file (
/etc/default/grub
):GRUB_CMDLINE_LINUX="default_hugepagesz=2M hugepagesz=2M hugepages=1200"
For the hypervisor host on RHEL, add the following to the
/etc/sysctl.conf
file:vm.nr_hugepages = 1200
Step 2: Update the configuration to make HugePages effective.
For Ubuntu, run the following commands in the terminal:
sudo update-grub
sudo grub-mkconfig -o /boot/grub/grub.cfg
Reboot your system.
For RHEL, run the following commands in the terminal:
sysctl -p
Confirm the output is correct.
Reboot your system.
Step 3: Check the HugePages configuration after the host reboot.
- Enter
cat /proc/meminfo | grep Huge
- Confirm the configuration settings are correct.
AnonHugePages: 6100992 kB
ShmemHugePages: 0 kB
HugePages_Total: 1200
HugePages_Free: 1200
HugePages_Rsvd: 0
HugePages_Surp: 0
HugePagesize: 2048 kB
Create a new virtual network to use with your KVM site. Perform these steps only if you are creating a KVM site using the terminal.
Step 1: Create a new libvirt network.
In the terminal, use the
touch
command to create an XML file with a.xml
extension. -
Open the XML file using
vim
ornano
text editors. -
Populate the network fields. Set a different subnet other than the underlay network.
This example provides sample file entries:
<network>
<name>virtualnetwork1</name>
<forward mode='nat'>
<nat>
<port start='1024' end='65535'/>
</nat>
</forward>
<bridge name='bridge1' stp='on' delay='0'/>
<ip address='192.168.122.1' netmask='255.255.255.0'>
<dhcp>
<range start='192.168.122.2' end='192.168.122.254'/>
</dhcp>
</ip>
</network>
- Save your information and close the text editor.
Step 2: Define the virtual network from the XML file created in Step 1.
In the terminal, enter sudo virsh net-define <virtual-network-name>.xml
Step 3: Start the virtual network and enable it for autostart.
- To start the network, enter
sudo virsh net-start <virtual-network-name>
- To enable autostart, enter
sudo virsh net-autostart <virtual-network-name>
Step 4: List the libvirt networks to verify that the virtual network was created.
To list the libvirt networks, enter sudo virsh net-list
sudo virsh net-list
This example provides sample output:
Name State Autostart Persistent
default active yes yes
virtualnetwork1 active yes yes
Step 5: Optionally, list your bridge devices.
Enter brctl show
brctl show
bridge name bridge id STP enabled interfaces
virbr0 8000.5254003339b3 yes virbr0-nic
virbr1 8000.52540060f86e yes virbr1-nic
Create and install a node the using the terminal.
Step 1: Create a Virtual Disk Image (VDI) file.
- In the terminal, enter
sudo qemu-img create /var/lib/libvirt/images/volterra.qcow2 45G
This example creates a virtual disk file with name volterra.qcow2 45G
Step 2: Create a new virtual machine.
This list provides the option descriptions for the virt-install
command:
name
: Name of the guest virtual machine. -
ram
: RAM allocation for guest virtual machine (minimum 8 GB, recommended 16 GB). -
vcpus
: The CPU allocation for guest virtual machine (minimum 4). -
network
: The name of the virtual network that the Customer Edge (CE) server should be attached to. You can also specify bridge for network. -
disk path
: The virtual disk path. -
cache
: Ensure that thecache=none
option is specified in the command.
Note: KVM installation is supported only for the SCSI disk type and virtio model for
network
type.
- Run the
virt-install
command with the following options set:
sudo virt-install --name Volterra --ram 14000 --vcpus=4 --network network=virtualnetwork1 model=virtio --accelerate -–disk path=/var/lib/libvirt/images/volterra.qcow2 bus=virtio cache=none size=64 --cdrom /scratch/RHEL-9.2023.29-Installer.iso --noautoconsole --noreboot
Step 3: Optionally, start the virtual machine.
Start the virtual machine using the virsh
command. Note that in some cases the virtual machine may not start yet.
- Enter
sudo virsh start <node-name>
Step 4: Verify the status of the virtual machine.
- Enter
sudo virsh list –all
sudo virsh list --all
This example provides the sample output of the command:
Id Name State
31 ce-volterra running
Step 5: Connect to the virtual machine using console.
- Enter
sudo virsh console 31
Connected to domain ce-volterra
Escape character is ^]
This is localhost (Linux x86_64 4.19.56-coreos-r1) 22:53:47
SSH host key: SHA256:aIFHRiKcjFWaF47+9AAd6IGzCQ5M6suHzL0xH3QUaS4 (ECDSA)
SSH host key: SHA256:hmWTu9M5GYKDQcTgks7LDTkQK9LXKhQjSodVO14JICo (ED25519)
SSH host key: SHA256:ewojrrFELDNOZWIW+jp2UgSaQVikpnGupdbu9+ObgZw (RSA)
SSH host key: SHA256:dM0wUNcFqfJxVRGwwzOJBLtTY1JdptmtjyHXthnBKqY (DSA)
eth0: 192.168.122.197 fe80::5054:ff:fe89:abb8
Step 6: Optionally, connect to the virtual machine using IP address.
Enter sudo virsh domifaddr ce-volterra
Name MAC address Protocol Address
vnet0 52:54:00:89:ab:b8 ipv4 192.168.122.197/24
Create and install a node using the Virtual Machine Manager GUI. The Virtual Machine Manager application requires that you pre-install the virt-manager
package.
Step 1: Initiate the Virtual Machine Manager on the hypervisor host.
For RHEL: Launch the application from
Applications
>System Tools
For Ubuntu: Launch the application from
Applications
From a terminal, enter
virt-manager
Step 2: Create a virtual network.
Click
Edit
>Connection Details
Follow the instructions at CREATING A VIRTUAL NETWORK to complete the virtual network set up.
Step 3: Create a virtual machine.
- Click
Select
Import existing disk image
Confirm the installation information is correct, and then click
Forward
Step 4: Select the node ISO file for installation.
- Click
Browse
to navigate to and then select the file.
- Click
Forward
Step 5: Configure memory and CPU settings.
In the
Memory
field, use the+
or–
buttons to set the memory amount. -
In the
CPUs
field, use the+
or–
buttons to set the number of CPU cores. -
Click
Forward
Step 6: Configure the disk image settings.
Confirm the option for
Enable storage for this virtual machine
is enabled. -
Under the
Create a disk image for the virtual machine
field, use the+
or–
buttons to set the amount of storage. -
Click
Forward
Step 7: Configure the network.
From the
Network selection
drop-down menu, selectVirtual network ‘default’ : NAT
Confirm all other settings are correct.
Click
Finish
Step 8: Configure the NIC driver and CPU.
- For the NIC driver, confirm the settings are correct, or adjust them and then click
Apply
- For the CPU(s), confirm the settings are correct, or adjust them and then click
Apply
Step 9: Complete the creation of the virtual machine.
Click
Finish
Start the virtual machine from the Virtual Machine Manager GUI options.
After the image/qcow file is installed, you must perform initial node parameter configuration.
Step 1: Sign in to the node.
Log into the node using the default credentials of
admin
for the username andVolterra123
for the password. If you did not sign in previously, you will be prompted to update the default password for theadmin
username. Follow the instructions to update the default password. -
Press the
Tab
key to select parameters to configure. The login terminal loads with different options to select for configuration.
Step 2: Verify the configuration.
Select
get-config
Confirm the settings are correct.
Step 3: Optionally, perform network and Wi-Fi configuration.
- Select
configure-network
. Follow the prompts to configure network settings.
Note: You cannot change an IP address for a registered node for a multi-node site. You must use fixed IP addresses or DHCP addresses with a fixed lease. When configuring an HTTP proxy server, IPSec tunneling is not supported.
Optionally, configure your Wi-Fi network. If you want to apply static configuration, then this option can be used. Perform the following:
- For the
Do you want to configure wifi?
option, enterY
and follow the on-screen instructions.
- For the
Step 4: Configure the main options.
You must first perform network configuration using the configure-network
option before setting the other fields using the configure
option, in case you are applying static configuration for the network. Also, note that changing the assigned IP address after the successful registration of the node is not supported in cases of multi-node sites.
Press the
Tab
key to select theconfigure
option. -
Enter the registration token.
Enter a site name.
Enter a hostname. Ensure that hostnames are unique if you are installing nodes for a multi-node site.
Enter the longitude and latitude information.
Optionally, enter a fleet name.
Select
kvm-voltmesh
for the certified hardware, if not done so previously.
Certified Hardware: The supported options are as follows.
kvm-voltmesh
: Single service level objective eth0 interface hardware. -
kvm-voltstack-combo
: For managed k8s and vk8s use cases. -
kvm-regular-nic-voltmesh
: Two virtual NICs, when eth0 is SLO dedicated and eth1 is binded as regular interface, which can be optionally configured from Console post registration.
Note: The default option is
, and this supports 2 interfaces (ensure that both eht0 and eth1 are available). However, this is loaded by default with eth0 interface set as a dedicated site local outside interface. The other interface is an optional regular interface and can be only configured from Console using fleet after the site is provisioned. For instructions on configuring interfaces using fleet, see Create a Fleet document.
Note: For more information on choosing an appropriate image for your certified hardware, see How to choose an image for your site deployment?.
Step 5: Confirm configuration.
Enter Y
to confirm configuration.
Step 6: Verify configuration status.
Press the
Tab
key to select thehealth
option. Use theEnter
key to scroll down for more information. -
Verify your network configuration and registration status.
Note: You can select the
factory-reset
option to perform a configuration reset and repeat the registration process again per the instructions below.
Note: If you use an NTP server, ensure that the server is reachable. Else, leave the NTP server configuration empty so that the F5 Distributed Cloud NTP servers are used.
- Use the
q
key to exit the health information page.
Register the Site
After the Distributed Cloud Services Node is installed, it must be registered as a site in Console.
Note: The USB allowlist is enabled by default. If you change a USB device, such as a keyboard after registration, the device will not function.
Step 1: Navigate to the site registration page.
Log into Console.
Click
Click
Manage
>Site Management
>Registrations
Step 2: Complete site registration.
Under
Pending Registrations
, find your node name and then click the blue checkmark. -
In the form that appears, fill in all required fields with the asterisk symbol (
If you did not previously, enter a latitude value and a longitude value.
Enter other configuration information, if needed.
Click
Save and Exit
Step 3: Check site status and health.
It may take a few minutes for the site registration information to update.
Click
Sites
Click on your site name. The
Dashboard
tab appears, along with many other tabs to inspect your site. -
Click the
Site Status
tab to verify the following:-
The
Update Status
field has aSuccessful
value for theF5 OS Status
section. -
The
Update Status
value for theF5 Software Status
section. -
The
Tunnel status
andControl Plane
fields under theRE Connectivity
section haveup
values.
Log into Console.
Click
Click
Manage
>Site Management
>Registrations
Step 2: Accept the registration requests.
Registration requests are displayed in the Pending Registrations
tab.
Click
Accept
to accept the registration requests from themaster-0
,master-1
, andmaster-2
nodes. Your node names will differ. -
Enter the same values for the following parameters for all the registration requests:
In the
Cluster name
field, enter a name for the cluster. Ensure that all master nodes have the same name. -
In the
Cluster size
field, enter3
. Ensure that all master nodes have the same cluster size.
Enter all mandatory fields marked with the asterisk (
) character.
It may take a few minutes for the site health and connectivity score information to update.
Click
Sites
Click on each of your site names. The
Dashboard
Click the
Site Status
The
Update Status
section. -
The
Update Status
section. -
The
Tunnel status
andControl Plane
section haveup
values.
Create and deploy a single-node KVM site using Terraform.
Step 1: Confirm Terraform is installed.
Terraform can be located on a different node than the host running KVM. In the main.tf
file cloned in Step 4, you can change the uri
variable under provider
to point to your KVM location.
In a terminal, enter terraform version
. If you need to install, follow the instructions at the official guide.
Step 2: Confirm hardware virtualization is enabled.
To confirm hardware virtualization is supported by your CPU, enter
egrep -c '(vmx|svm)' /proc/cpuinfo
. This command returns a non-zero number if virtualization is enabled. For example, if a2
is returned, then your system supports virtualization. If a0
is returned, then your system does not support virtualization. -
To confirm KVM acceleration for Ubuntu-based systems only, enter
sudo kvm-ok
. Confirm the output is the following:
INFO: /dev/kvm exists
For Ubuntu only:
- If
sudo kvm-ok
does not work, entersudo apt install cpu-checker
. Then rerun thesudo kvm-ok
command.
- If
Step 3: Confirm KVM is installed.
For your specific Linux distribution, the installation will be different.
For information on Ubuntu, see KVM Installation.
For information on Red Hat, see Installing KVM packages on an existing Red Hat Enterprise Linux system.
Ubuntu
Update your software package repository. Enter
sudo apt update
To install the necessary packages, enter
sudo apt-get install qemu-kvm libvirt-daemon-system libvirt-clients bridge-utils
If asked to confirm installation, enter
y
Confirm your username is added to these groups:
kvm
andlibvirt
sudo adduser \`id -un\` libvirt
sudo adduser \`id -un\` kvm
Reboot your machine for the changes to take place.
Confirm installation and configuration is applied correctly. Open a terminal and enter
virsh list --all
To use libvirt with the XML extension, install with
sudo apt install xsltproc
RHEL
sudo yum update
. Entery
to confirm. -
sudo yum install qemu-kvm libvirt-daemon-system libvirt-clients bridge-utils
y
kvm
andlibvirt
. If not, add them. -
virsh list --all
sudo yum install xsltproc
Step 4: Clone repository folder.
Navigate to KVM-CE and use Git to clone the repository folder to your desired location.
In a terminal, navigate to the directory where the cloned repository folder is.
Enter
cd kvm-ce-main/terraform/
Confirm that the following folder and three files now exist in the current directory with
ls -lh
cloudinit
cpu-pinning.xsl
main.tf
var.tf
Step 5: Provide values for the variables.
Open the var.tf
file and provide all necessary values for the variables. For information on the values, see KVM CE Deployment.
Step 6: Optionally, add another network interface.
- Add another interface (eth1 - inside) in the
main.tf
(kvm-ce libvirt_domain resource).
network_interface {
network_name = "default"
network_interface {
network_name = "inside"
- In Console, configure your Fleet with interface assignment to outside and inside. See example below.
Step 7: Increase file system partition.
Use the
wget
command to download the KVM CE qcow2 image. -
Enter
qemu-img resize
command to resize the virtual disk storage. For example:qemu-img resize rhel-9.2023.29-20231212011947.qcow2 50G
In the
var.tf
file, update thekvm-ce-qcow2
variable to point to the local qcow2 image downloaded previously.
Step 8: Apply Terraform parameters.
Enter
terraform init
Enter
terraform apply
Step 9: Confirm site deployed.
In Console, navigate to the list of sites to register and confirm your site is on the list.
After you create and register your site, you can access its local user interface (UI) to perform certain configuration and management functions. For more information, see Access Site Local User Interface.
