Create Kubernetes Site
On This Page:
Objective
This guide provides instructions on how to deploy an F5® Distributed Cloud Services Site as a pod on a Kubernetes (K8s) cluster. For more information on Sites, see F5 Distributed Cloud Site.
Deploying a Site as a pod on a K8s cluster is supported for the following:
Note: This feature provides basic functionality of launching a Distributed Cloud Services Site on K8s with limited functionality, tools, and observability.
A Site deployed as a pod on a K8s cluster acts as a K8s ingress controller with built-in application security. It also enables the F5® Distributed Cloud Mesh (Mesh) features, such as discovery of services of the K8s cluster, publish of other Site's services on this Site, publish of this Site's discovered services on other Sites, etc.
F5 Distributed Cloud Services platform supports deploying a Site on a K8s cluster either using kubectl or Helm charts and both methods are covered in this guide.
Note: A Site deployed with Kubernetes only supports Mesh functionalities and does not support F5® Distributed Cloud App Stack. The supported Kubernetes version is 1.23. Only one or three pods are supported per cluster when deploying a customer edge (CE) site on K8s.
Using the instructions provided in this guide, you can perform the following:
Deploy a Site of the nodes
Decommission the Site from the K8s cluster
Prerequisites
The following prerequisites apply:
A Distributed Cloud Services Account. If you do not have an account, see Create an Account.
A deployed K8s cluster. For documentation on deploying:
The following requirements are for the managed K8s environment:
Managed K8s (EKS/AKS/GKE): minimum 4 vCPUs and 14 GB of memory per node.
Minikube: minimum 14 GB of memory per node.
Note: The driver should support HugePages for managed K8s. For example, for macOS you can use the
minikube start --driver=<driver>
command to start Minikube with the driver that supports HugePages. For example, use theminikube start --driver=virtualbox --memory 14336
command to start Minikube with VirtualBox driver.
- Kubernetes StorageClass with enabled Dynamic Persistent Volume Provisioner (PVC) with a minimum of 1 GB space.
Note: Use the
kubectl get storageclass
command to check if dynamic PVC is enabled for your K8s StorageClass. The output with an entry withstandard (default)
in theNAME
column indicates that K8s storage class is enabled with Dynamic PVC.
Helm 3.2.0+ in case using Helm chart to deploy Site. See Helm Docs for more information on Helm.
Internet Control Message Protocol (ICMP) needs to be opened between the CE nodes on the Site Local Outside (SLO) interfaces. This is needed to ensure intra-cluster communication checks.
Restrictions
The following are not supported in case of advertising load balancer on Kubernetes Site:
- Fast ACLs
- Service Policy - Rejecting requests from specific source IP address
- Trusted client - Adding a specific source IP address as trusted client in load balancer
- API protection rules - Adding a rule with specific IP address
- API Rate Limiting - Based on Source IP address
- Blocked clients - Adding a specific IP address to blocker clients
- Malicious User Mitigation - Setting IP address or IP address plus TLS fingerprint as user identifier
Configuration
You can deploy Site as a pod either through Kubectl using a manifest file or using Helm charts.
Kubectl-Based Configuration Sequence
Deploying a Site as a pod on an existing K8s cluster using Kubectl requires you to perform the following sequence of actions:
- Create a Site token.
- Prepare a manifest file with the parameters required for Site provisioning.
- Deploy the Site using the kubeconfig of the K8s cluster and the manifest file.
- Perform Site registration.
- Verify that Distributed Cloud Services are running.
Helm-Based Configuration Sequence
Deploying a Site as pod on an existing K8s cluster using Helm requires you to perform the following sequence of actions:
- Create a Site token and set Site token environment variable.
- Clone the F5 Distributed Cloud Services Site on K8s Repo.
- Deploy the Site using the Helm installation command.
Note: In both methods, ensure that you have reachability to your K8s cluster and set the kubeconfig environment variable with the kubeconfig of your K8s cluster using the
export KUBECONFIG=<kubeconfig.yml>
command.
The following video shows the deployment workflow using Kubectl and manifest file.
Create Site Token
Create a site token or use an existing token. If you are configuring a multi-node site, use the same token for all nodes.
Step 1: Navigate to site tokens page.
Log into F5® Distributed Cloud Console.
Click
Multi-Cloud Network Connect
Select
Manage
>Site Management
>Site Tokens
Click
Add Site Token
to create a new token.
Step 2: Generate a new site token.
In the
Name
field, enter the token name. -
In the
Description
field, enter a description for the token. -
Click
Save and Exit
Step 3: Note down the new token.
Find the token previously created or choose an existing token from the list of tokens displayed.
Click
to expand the token details in JSON format and note down the value of theuid
field.
Deploy Using Kubectl
Deploying Site using kubectl involves preparing a manifest file and performing kubectl apply operation on the K8s cluster.
Prepare the Manifest File
The manifest file contains a YAML schema used for descriptor information to support deployment of Kubernetes for a Site.
Step 1: Create the manifest file.
Download the sample Manifest Template.
Step 2: Edit the configuration.
Edit the configuration of the manifest file per the following guidelines:
In the
ClusterName
field, type your cluster name. -
In the
Latitude
andLongitude
fields, type the latitude and longitude values. -
In the
Token
field, type the Site token. -
In the
replicas
field, enter 1 for a single-node Site or 3 for a multi-node Site.
Save your changes.
This image provides a manifest file example:
Note: You can also set the cluster name, latitude, and longitude when you register a Site.
Deploy Site
Step 1: Deploy the Site using the kubeconfig file for the K8s cluster and manifest file.
- Type
kubectl apply -f <manifest>.yml
This example displays the sample output of the command:
namespace/ves-system created
serviceaccount/volterra-sa created
role.rbac.authorization.k8s.io/volterra-admin-role created
rolebinding.rbac.authorization.k8s.io/volterra-admin-role-binding created
daemonset.apps/volterra-ce-init created
serviceaccount/vpm-sa created
role.rbac.authorization.k8s.io/vpm-role created
rolebinding.rbac.authorization.k8s.io/vpm-role-binding created
clusterrolebinding.rbac.authorization.k8s.io/ver created
configmap/vpm-cfg created
statefulset.apps/vp-manager created
service/vpm created
Step 2: Verify that the K8s pod for the Site was created.
Verify that the pod with the vp-manager-0
under the NAME
column indicates that the Site pod was created.
- Type
kubectl get pods -n ves-system -o=wide
This example displays the sample output of the command with minikube for a single-node Site:
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
volterra-ce-init-g8bd7 1/1 Running 0 7m15s 172.16.11.6 minikube <none> <none>
vp-manager-0 1/1 Running 0 6m19s 172.17.0.7 minikube <none> <none>
This example displays the sample output of the command with minikube for a multi-node Site:
volterra-ce-init-sgklz 1/1 Running 0 4m 172.16.11.12 minikube <none> <none>
vp-manager-0 1/1 Running 0 3m59s 172.17.0.3 minikube <none> <none>
vp-manager-1 1/1 Running 0 3m24s 172.17.0.4 minikube <none> <none>
vp-manager-2 1/1 Running 0 3m16s 172.17.0.5 minikube <none> <none>
Step 3: Check if the registration request was created.
You can check the request status from the Console or the kubectl
command-line tool.
To check with Console:
Log into Console and then click
Click
Manage
>Site Management
>Registrations
>Pending Registrations
To check with
kubectl
:- Type
kubectl logs vp-manager-0 -n ves-system
- Type
This example provides the sample output of the command:
Current state: PENDING, registration fe5b5157-7066-4052-95f3-5b9d68e072c6 must be manually APPROVED and then automatically ADMITTED. Object status: &StatusType{ObjectStatus:&ves_io_schema4.StatusType{Status:,Reason:,Code:0,},CurrentState:PENDING,};2022-03-09 21:28:17.07967128 +0000 UTC m=+1318333.138793540,, waiting 15.716434773s before next try
Deploy Using Helm
Step 1: Set environment variables required for deployment.
Enter the following commands:
export SITE_NAME=<site-name>
export SITE_TOKEN=<site-token>
Note: The
site-name
is a name of your choice. Thesite-token
is the token created in the Create Site Token chapter.
Step 2: Clone the F5 Distributed Cloud Services K8s Site repo.
Enter the following commands to clone the repo and change to its directory:
git clone https://gitlab.com/volterra.io/volterra-ce.git && cd volterra-ce
Step 3: Deploy the Site.
Enter the following command for AWS, Azure, GCP, and Minikube:
helm upgrade --install \$SITE_NAME ./helm --set vpm.clusterName="\$SITE_NAME" --set vpm.token="\$SITE_TOKEN" --set vpm.latitude="50" --set vpm.longitude="50" --set siteToSiteNodePort.enabled=false
Enter the following command for OCP:
helm upgrade --install \$SITE_NAME ./helm --set vpm.clusterName="\$SITE_NAME" --set vpm.token="\$SITE_TOKEN" --set vpm.latitude="50" --set vpm.longitude="50" --set siteToSiteNodePort.enabled=true
The following is a sample output for the above command:
Release "alexminikube2" does not exist. Installing it now.
LAST DEPLOYED: Thu Dec 8 18:31:36 2022
NAMESPACE: default
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
Please open https://console.ves.volterra.io/ and proceed to site registration.
Register the Site
After the Distributed Cloud Services Node is installed, it must be registered as a Site in Console.
Note: The USB allowlist is enabled by default. If you change a USB device, such as a keyboard after registration, the device will not function.
Single-node Site Registration
Step 1: Navigate to the Site registration page.
Click
Manage
>Site Management
>Registrations
Step 2: Complete Site registration.
Under
, find theCluster Name
and then click the blue checkmark. -
In the form that appears, fill in all required fields with the asterisk symbol (
Enter a latitude value and a longitude value, if needed.
Enter other configuration information, if needed.
Click
Save and Exit
Step 3: Check Site status and health.
It may take a few minutes for the Site health and connectivity score information to update.
Click
Sites
>Site List
Click on your Site name. The
Dashboard
tab appears, along with many other tabs to inspect your Site. -
Click the
Site Status
tab to verify the following:-
The
Update Status
field has aSuccessful
value for theF5 OS Status
section. -
The
Update Status
value for theF5 Software Status
section. -
The
Tunnel status
andControl Plane
fields under theRE Connectivity
section haveup
values.
Multi-node Site Registration
Click
Manage
>Site Management
>Registrations
- Under
and then click the blue checkmark. You must perform this step for each of the nodes.
Enter the same values for the following parameters for all the registration requests for each of the nodes:
In the
Cluster Name
field, enter a name for the cluster. Ensure that all master nodes have the same name. -
In the
Cluster Size
field, enter3
. Ensure that all master nodes have the same cluster size.
Enter information for all mandatory fields marked with the asterisk (
) character. -
Click
Save and Exit
Click
Sites
>Site List
Dashboard
Click the
Site Status
The
Update Status
section. -
The
Update Status
section. -
The
Tunnel status
andControl Plane
section haveup
values.
Verify Services
Verify that services were started after Site registration.
Type kubectl get pods -n ves-system -o=wide
etcd-5779568655-td4wq 2/2 Running 0 41m 10.244.1.4 aks-nodepool1-29573508-vmss000001 <none> <none>
etcd-defrag-1587094200-58jjb 0/1 Completed 0 33m 10.244.1.5 aks-nodepool1-29573508-vmss000001 <none> <none>
ver-0 13/13 Running 3 41m 10.244.0.8 aks-nodepool1-29573508-vmss000000 <none> <none>
volterra-ce-init-5wsmb 1/1 Running 0 75m 10.240.0.5 aks-nodepool1-29573508-vmss000001 <none> <none>
volterra-ce-init-sbjqp 1/1 Running 0 75m 10.240.0.4 aks-nodepool1-29573508-vmss000000 <none> <none>
vp-manager-0 1/1 Running 2 72m 10.244.1.3 aks-nodepool1-29573508-vmss000001 <none> <none>
The Site appears in Console, where you can deploy Mesh services.
Decommission a Site
Decommissioning a Site requires you to deregister the Site from Console, and then delete that Site.
Step 1: Navigate to the list of registered Sites.
Log into Console.
Click
Click
Manage
>Site Management
>Registrations
Click the
Other Registrations
tab.
Step 2: Perform decommissioning.
Find your Site and then click
Click
Decommission
- Click
Decommission
in the confirmation window to confirm the operation. After a few minutes, theCurrent State
column will displayRETIRED
Step 3: Delete the resources for the Site.
- In the terminal, use the
kubectl
tool to delete if Site is created using the manifest file.
Type kubectl delete -f <vpm-manifest>.yml
- Use the cloud provider commands to delete the resources if Site is created using Helm. The following are sample commands for AWS, Azure, and GCP.
eksctl delete cluster --name \$SITE_NAME --region us-west-2
gcloud container clusters delete --region us-west1 \$SITE_NAME
az aks delete --resource-group \$SITE_NAME --name \$SITE_NAME
Step 4: Delete the decommissioned Site.
Click
Sites
>Site List
Find your Site from the list and then click
Click
Manage Configuration
to open the Site edit form. -
Click
Delete Site
- Click
Delete
in the confirmation window to complete the operation.
Perform Scaling for a Site
You can perform a scale-up or scale-down of Site nodes by changing the replicas of the vp-manager
pods.
Note: Scale-up for the Sites also creates the VER pods, as there can be only one VER pod per node.
Step 1: Update the replicas using the kubeconfig file for the K8s cluster.
- Type
kubectl --kubeconfig=<kubeconfig-of-existing-k8s-cluster> edit statefulset/vp-manager -n ves-system
In the kubeconfig file
replicas
field, enter a new number. -
Save the file. The changes are applied automatically.
Step 2: Verify that the new pods have started.
- Type
kubectl get pods -o=wide -n ves-system
This example assumes that the replicas are set to 2:
etcd-5bcbfc8689-8fx4g 2/2 Running 0 19h 10.244.1.23 aks-nodepool1-29573508-vmss000001 <none> <none>
etcd-defrag-1587184200-dg765 0/1 Completed 0 42m 10.244.1.52 aks-nodepool1-29573508-vmss000001 <none> <none>
ver-0 13/13 Running 2 16h 10.244.0.12 aks-nodepool1-29573508-vmss000000 <none> <none>
ver-1 13/13 Running 0 17m 10.244.1.53 aks-nodepool1-29573508-vmss000001 <none> <none>
volterra-ce-init-5wsmb 1/1 Running 0 26h 10.240.0.5 aks-nodepool1-29573508-vmss000001 <none> <none>
volterra-ce-init-sbjqp 1/1 Running 0 26h 10.240.0.4 aks-nodepool1-29573508-vmss000000 <none> <none>
vp-manager-0 1/1 Running 0 12m 10.244.1.54 aks-nodepool1-29573508-vmss000001 <none> <none>
vp-manager-1 1/1 Running 2 15m 10.244.0.14 aks-nodepool1-29573508-vmss000000 <none> <none>
